No, the compression of the combustion chamber is sealed off from the water ports, as long as the gasket is intact and sealing, then its doing its job and the motor will run fine.it has all original caps on it , could it have anything to do with me having the head cut and running a thinner head gasket? maybe i took too much off and should run stock gasket?
Original radiator caps don't often fail, but they do fail, so go get a new radiator cap, install it and your issues should be resolved.
There is a fine balance that smart people worked out between the cooling capabilities of the coolant system, the pressure it runs at a certain temperature and so on, so if the cap's spring tension changes over time, or the rubber seal goes hard or any one of a few other possibilities why the cap fails, the system is not balanced, and it will eject fluid.
