Hello everyone this is my first post. hopefully my question can be answered. I recently purchased a 1991 gsxr 750 but the PO broke what I believe is the fuel over fill tubes. I was wanting to know if anyone has modified these tubes or found the brass and 90 degree plastic fittings. please let me know thanks!
If it goes down to the float bowl it'll be the power jet feed - they had those on the 750 38mm carbs, beyond that I don't know too much as I've not worked on one - if you do a search on here you'll find a bunch of threads on the subject.
Hello Chinchy. If you're interested, I have a set of carb bodies with bowls that have all the elbows intact. PM me if that's something you could use.
