1 - 15 of 15 Posts
Ok i have an extra tank which doesnt have the breather valve on the top so i check the tank and i order one from ronayers. The thing is to small for the hole.. looks like it needs something esle there before the breather valve....
Anyone has one???????/ Help i need to paint the tank next week!
The old tank has this thing welded!
Help!
I have a perfect blue 750/1100 tank in my basement I bought off ebay two years ago for $25!! And it has the same "big" hole!! I would like to get some info on this as well! I was thinking of matching a big ass bolt to the threads and drilling it out and tapping the threads for the small valve. Anyone have a part # for the right valve?
Astroman76
My 86 is a California model with the EXTRA large valve.
It also has a vent on the right underside that a hose connects to.
That hose connects to the (California only)canister.
You might want to check to see if that is on this tank too ?
I don't know if it will cause any problems though.
Discussion Starter · #10 ·
Astroman76
i just checked for that. yes i does have another exit but after further inspection i found out that this exit is just another overflow thing just a bit lower than the overfolw used on the 49 state... I have to bend it a bit and would work.
I have a CA tank that I don't need, and it has the valve on it, but the tank has a huge dent in it, the tank could be repaired but I have no need for it. I'll look at it tomorrow and check the hole size and see if it will work, if so, it's yours.
Yeah I think I'd also take that one way valve and head to a hardware store and see if I could find a brass reducer that would work.
Bobbychet
I agree or a stainless steel bushing would work something like this
1 - 15 of 15 Posts
