I put the temp sensor into the oil galley plug by the oil filter...remove the plug with a hex driver(5 mm, I think) and pop the sensor in. I did it real quick, didn't even drain the oil...then run the wiring up the cradle on the left side of the bike..try to keep it away from the exhaust, secure with zip ties as needed.
Does yours need 12v to power it, or does it have it's own battery??
Best of luck!!!
