Just changed my oil. Should the oil window appear full to the top when my bike is uprite. Right now its 3/4 filled. I put in 2.6 quarts like the manual says. Thx.
Bearded Viking Admin...
There's a Min and a Max mark - as long as it's between them it's just fine :thumbup
Thx for replying man. But my window doesn't seem to have a min max mark unless I'm an idiot wich is a distinct possibility. The window itself is 3/4 full tho. It doesn't say f or l or min or max
hey whats up guys
I know I'm opening an old thread, but it was the closest I could find to my question..
Did an oil change and poured a bit too much (attached pic)... do I need to drain some of this or do you think it's okay?
if I need to drain some oil, can i just open the oil drain plug slightly to let some out or maybe empty some from the oil filter? (did the change with amsoil so if i can avoid having to redo it that would help my wallet)
Thanks in advance :punk
Looks like it's AT the FULL mark, so it should be fine, but I'd let a bit out anyway.
Just loosen the drain bolt to let a little out, just go slowly so you don't let too much out. As you said, you paid good money for it :thumbup
