Hi all,
I've had a slight oil leak from around the front sprocket area on my 96 750 for a while now and decided to change the gear selector rod oil seal yesterday but the oil leak is still there.
The oil is running onto the side stand when its up and there is always a drip under the black metal case which sits over the sprocket. Could it be the seal around the drive shaft behind the front sprocket which is leaking cos Im all out of ideas.
Is there anywhere else under that case it can be leaking from cos it seems that there is only 2 seals under there.
Thanks for any suggestions, its not a big leak but I dont want it suddenly getting bigger cos theres only one place it will end up and that aint good
Regards
N|nj
Regards
N|nj
