Does anyone have a diagram of the path the oil takes after leaving the pump on a '01 gsxr750? Does all of it have to go thru the filter before going anywhere else? I have no oil pressure at the pressure sensor, verified with a pressure gauge. With the gauge and sensor removed, oil does not even drip out of the sensor's mounting hole. I removed the pump and it is fine. What is going on here.
BTW, the bike was crashed at the track and the problem started after that.
Pick up tube was fine. After some researching I found out that all I had to do was loosen the oil filter, start the engine, wait for oil to leak out (about 5 seconds) re-tighten the filter and it works fine.
IF the bottom end is OK...
