Hey, back in time, i bought a k9 1000 with full
akrapovic racing line system on it. There was red
"Fl' light on, because of 02 sensor unpluged.
To turn off that ugly "Fl" light, i followed some
manual (i think from yoshimura full system) and
do the trick with wires from the ECU and finally
that red light goes off forever.
So my question is: Can someone explain me the
sitoation here, in more details. I know that o2
sensor is there to regulate the air/fuel ratio. But
what happens if the sensor is removed and
bypassed? (Like in most cases with full exhaust systems on) Does in this situation, ecu is using the standard A/F ratio all the time?(14.7:1 is the standard ratio for k9 1000) What is the positive and what is the negative effects? What is better… With plugged or unplugged o2 sensor?
here is mine,
-o2 sensor unpluged
-Also o2 connector unpluged (up there) so, the whole sensor is unplugged.
-Wire from ecu unpluged (to fix Fl light on dash)
Edit: after posting this thread, i found that i have o2 eliminator on my bike, and that Fl light that i solved with removing the 5th black/white wire from the ecu was from the removed servo exhaust valve instead of unplugged o2 sensor, as i thought before. (Because with o2 eliminator, there would not be Fl light)
here is mine,
-o2 sensor unpluged
