YAAFM Mod
I got the 01 750 swingarm for my 90. at first glance looked close.
1st rule: DON'T GLANCE!
The Pivot is the same width but the bearings are a different ID. Strage thing is the OD of the 90 insert has the the same OD as the 01 inserts ID!
The dog bone mount on the 88-95 is on the top of the arm and the 01 is on the bottom.
2nd rule: If welding is needed look for a Boat shop. tTo cut the mount off my spare 88 arm and weld it in the correct place on the 01 arm:
Aircraft Welder: 250.00 and 2 weeks to fit it in.
Boat Builder: 80.00 and couple of days.
I may still need to adjust the spacers to center the wheel once its mounted on the 90 as the 01 arm is about 19mm wider at the wheel (mostly on the Sproket side).
All this to a bike there was nothing wrong with...
Winter in Alaska is boring.
Bones
Bones
<font size="2" face="Verdana, Arial">This especially applies to you guys in Kansas, Wyoming, Idaho, Montana, both Dakotas, Alberta and Colorado. Even if it means dragging everything to Los Angeles
