I tried to set my rider sag today and found that i do not have enough weight on the front.Seems that the ohlins fork springs were too hard.The rear was sagging about 42mm without preload.Even with max preload,the rear still sags 36mm.Should i drop the front?The forks are now about 5mm above the triple clamps from the line on the fork.
How much sag do you have in the front? Is the preload adjuster all the way out on the front?
If your rear is still at 36mm with the preload all the way up then you need to send the shock in so they can re-adjust the preset preload adjuster.
I have 27mm of sag in the front.The preload adjusters are all the way out
[QB]How much sag do you have in the front? Is the preload adjuster all the way out on the front?
