Hi, guys,
I bought a GSXR 1000 K6 after accident, doesn’t look really bad so thinking to repair.To start with I have checked battery which is alive 12,7 with voltmeter. I checked fuses all ok, except main 30 in starter, changed that. Have to original keys, they go into lock and key works. But bike doesn’t show any signs that it’s alive.
Also to mention I don’t have speedo fitted no headlights, might speedo cause that it doesn’t show any signs? Anybody knows if these starts without speedo?
thanks in advance guys
The cluster only accepts information so it will start without it, but that's not a good idea except for a very brief time as you can't read the oil pressure light, temperature, or error codes.
A UK bike will have an immobilizer. There are associated indicator lights on the cluster that you won't be seeing.
With the key and engine stop switch turned on, measure the voltage at the O/G lead on the dealer mode connector and the R lead on the nearby SAP connector. They should be battery voltage and 5 V, respectively.
