Check the circuit breaker.
Just checked the circuit breaker, somehow I’m not getting any power to the red wire leading up to it. I’m assuming I have to dig into the main wiring to find out the short?Check the circuit breaker.
already checked. The connections are good for “on”.Ignition switch?
I’m using both a multimeter and a test light.Are you using a multi-meter or a test light?
When you say connections are "good", does that mean you have source(battery) voltage at each point that you test?
I used a multimeter to measure the voltage going from the positive end of the battery to the circuit relay. No power at all. But when I go from the negative terminal to the circuit, I get a reading.Do you have power on only one side of the circuit breaker, or nothing at all there?
