trogers013 said:weight.... its alot lighter... my friends use it on their bike and they said they notice a slight difference and it feels like there floating
At leat 10-20lbs:biggrinSPL170db said:Is that right? And just how much does the typical air volume inside a tire weight?
:biggrin
loltrogers013 said:weight.... its alot lighter... my friends use it on their bike and they said they notice a slight difference and it feels like there floating
thanks.vaa said:my GUESS is that you would run the same pressure as you would normally run. The benifit is that the Nitrogen is less affected by heat/cold and is bigger than air so you tire pressures will be more stable and less likely to get low.
Tire pressure is affected by cold quite a bit. It's shouldn't affect Nitrogen like that.
Not sure about the weight diff.
your basically saying the same thing as vaa. the others were joking:scratchCoffeecup said:disregard these idiots that have no idea about anything. the reason nitrogen is used is because it is very dry (no humidity) which means the pressure in a tire will change very little when temps change. an example where it is used is in aircraft tires at pressures over 200 psi. they go from 60 below zero at 40000 feet to getting very hot when the aircraft lands. presssure diff is minimal between the 2 temp extreems. now you know.
they use it on aircraft because displaces oxygen which means if the tires catch fire and explode, nitrogen can put out the fire on the tiresCoffeecup said:disregard these idiots that have no idea about anything. the reason nitrogen is used is because it is very dry (no humidity) which means the pressure in a tire will change very little when temps change. an example where it is used is in aircraft tires at pressures over 200 psi. they go from 60 below zero at 40000 feet to getting very hot when the aircraft lands. presssure diff is minimal between the 2 temp extreems. now you know.
hahahaha no actually coffeecup is exactly right! i know the benefits and reason for doing it but im just looking for real world feedback for people that have tried it. my main reason fir asking, especially about psi, is with air we set a "cold psi" whether it be for day to day use or going to the track, but since nitrogen is changing very little or not at all than where would i set my psi? :hammerGiXXer V1ct1M said:they use it on aircraft because displaces oxygen which means if the tires catch fire and explode, nitrogen can put out the fire on the tires
