1 - 18 of 18 Posts
i got my bike this past wednesday 5/10/06, and i got 252 on the odometer, i abosolutly love the bike. i do encounter a problem engaging 1st gear at a stop like some people have on this forum, but like they said alls i do is roll the bike forward and then roll it backwards and then it engages no problem...my question to you experienced riders out there is when coming to a stop whether it be a traffic light or stop sign, it doesnt make a difference, it makes me cringe to downshift into first, your never suppose to do that in a car, and i was just wondering should it be done on a regular basis on my bike or any bike for that matter? or should i wait until i come to a complete stop and then downshift into first...im not a moron i have been around cars a lot and worked on them may times over, but im sorry for the newbie question, i am new to motorcycles...
garrett
Bearded Admin call him Grizzly
dont know who told you that, I always downshift into first before coming to a stop. most of the time before im even on the brakes ;)
It's definitely no big deal shifting down into first as long as you're going slow enough before doing it. In a car that is especially true because you'll overspeed the clutch and could destroy it. (I actually downshifted to first at 50 when I was young and stupid and it blew the clutch apart even though I never engaged the clutch). I had that clutch plate turning at least twice the maximum RPM.
If you're down below 20-30 on that bike and especially if you blip the throttle to match engine speed it is no problem at all. I do it all the time. I've downshifted to first as high as 50 no problem.
As far as the going into first goes, that will all get easier as the transmission gears wear in. My own recommendation is to stay with regular oil for the first 5K miles to ensure a total break-in and then switch to a high end synthetic like Silkolene Pro4 plus. The synthetics really are that good that wear is pretty much eliminated at that point. Also, since they lubricate so well, once you make the swtch, the shifting will get better yet.
I've had 4 bikes so far, and that's what I've observed as the truth. I'm sure there's always someone to debate it, but........
Johncal
Same here, you should be looking and judging what is going to happen in front of you before it does, what if the lights change just as you roll to a stop? youre sat there looking like a noob rocking your bike back and forth rofl.:lol
its also good to be in first when you come to a stop just in case you have to move real fast to avoid that semi thats about to make you look like a greasy spot on the road
Yea, that is no joke. I had to make an emergency stop from about 90 last weekend while trying to catch up to my friends who were racing each other and a good way ahead of me. In my haste to stop, I didnt drop it down into first and it was the devil trying to get it down gears while stopped.
Try to blip gas while disengaged clutch at the stop. It helped me when I was riding my RS 125 which had problems shifting to first while at stop, but haven't got any that on my GSX-R 600 K6 :D
Yeah I kinda had this same question with these bikes and it doesn't feel natural yet to shift into first. My impulses from driving a 5 speed make me want to keep it in 2nd when I get slow, pull the clutch in and then give it a little bit extra of a rev to start from a slower roll in second. :wacko
Always downshift to first while coming to a stop. You should always be in the appropriate gear for your road speed, as mentioned before, if an emergency situation occurs and you need to get on the throttle to get out of the way it will save your life. Try hammering the throttle in second gear at 20MPH and you won't be going anywhere fast for a second or two, which might be the second or two you'll need. Also, why add to unneeded wear on the brakes when the engine can do most of it. If I'm riding around casual like, I don't even touch the brake(s) untill I'm down to 10-15MPH. Just blip the throttle to match your engine speed for each downshift, doesn't take long to make it second nature. Cheers.
just release clutch and pull it in again. should shift easily to 1st then
i use the engine too so don't think i'm trying to be a jerk...this was just the thought that came to mind when i read your comment.
but aren't brakes for braking and engine for accel. not engine for breaking? wouldn't that cause more wear and tear on your engine?
it's only going to hurt your engine if you are downshifting too early and that sucker is bouncing off the rev limiter. I think you should be downshifting and upshifting through every gear for the initial break-in so that every thing gets broken in properly. Mine also feels a lil clunky but shoudl clear up with more miles on it.
when I am in "N" at a stop light some times I cant get it into first. what I do is just roll back a hair and it goes in no prob. I also hear gears grinding whe going from 2nd to 1st. but only when I coast in 2nd with the cluch pulled in then tap down to 1st
1 - 18 of 18 Posts
