nice.. should be a good bike once you're finished, the FI bikes are way better than carb, unleaded E gas does not mess with it as bad.. still gotta watch that tank if it sits too long tho
Thanks. Regarding the tank, with the fuel pump removed, I can have a good look inside. There is some rust in the tank. What do people use to dissolve/remove that rust?nice.. should be a good bike once you're finished, the FI bikes are way better than carb, unleaded E gas does not mess with it as bad.. still gotta watch that tank if it sits too long tho
Thanks. Do I really need to use evaporust or some equivalent product? What if I just add vinegar to the tank, add a few nuts and bolts, slosh it around thoroughly let it sit for a couple of hours, then drain and flush with gas 3-4 times? Would that not be sufficient? To be honest, there not much rust in there. I'm not sure I need to do anything. Thoughts? And yes, I've ordered a new gasket.On evaporust, I think it tends to not flash rust as fast as other things do. Whatever you do, be sure to rinse completely and immediately slosh around something to recoat the tank away from bare metal. Such as oil/diesel/gas.
I had some interesting nightmares on a tank I did vinegar for too long with. Was more aggressive than I expected (also etched a lot) and ended up having to line the tank.
You're gona need to get a new gasket for the pump seating also. Use a torque wrench you can trust and fallow the torque pattern, otherwise you'll be opening up a whole 'nother can of worms.
Yep, tha'd prolly be sufficient. Manny ways to skin it.Thanks. Do I really need to use evaporust or some equivalent product? What if I just add vinegar to the tank, add a few nuts and bolts, slosh it around thoroughly let it sit for a couple of hours, then drain and flush with gas 3-4 times? Would that not be sufficient? To be honest, there not much rust in there. I'm not sure I need to do anything. Thoughts? And yes, I've ordered a new gasket.
Thanks. I was surprised at how good the bike looks considering its age and the fact that I only paid $500 for it. Hoping to receive my fuel pump rebuild kit by the end of the week so that I can install it and see if the bike will run.ride on! the bike appears promising. keep us updated with your progress.
If the bike is a keeper, just bite the bullet and get a new stator and the mosfet rr. Consider it an protection to your asset. When the stator goes, the oem rr frys fast (or vise versa) and your inevitably left with a burnt connector at best, or a cooked and brittle harness at worst. Might as well avoid the headache from the get go.Stator is putting out 55-60W at 5000 rpm. Should be at least 70W at 5000rpm for this 1998 750, as per the service manual. So not up to spec, but I'm hoping it is good enough. I haven't pulled the stator. Maybe if I pull it out and clean it it might put out more power? Thoughts?
