1 - 14 of 14 Posts
What's up guys? I haven't been on a forum since I was probably like 15, but i'm getting too old to care at this point. Thought I'd show y'all my retrofit headlight I just finished. It's not the easiest to get good pictures of, but this one is about as good as you can see the difference. Yeah, it's dirty... No I don't care if you give me hell for having a CS racing exhaust...I had a taylormade on my '07 750 too
Tire Wheel Fuel tank Vehicle Automotive fuel system
Tire Wheel Land vehicle Vehicle Fuel tank
Nice bike and the headlight looks good. But ah man that exhaust! 😝 Welcome to the forum
That thing is brighter than a police flashlight in a dark parking lot when you're trying to d-flop on a p-pop!
welcome, lets see at age 15 you prolly were on forums around the early 2000's so that would make you what 35ish? there are many here 50+ so you be just a puppy if my math is close... nice gixxer btw...
Pretty close! 33 almost 34! But, it's good to know there's some maturity on this forum. That's the reason I got away from them. Too many "cool guys" and cliques. Thanks for the compliment.
"custom made this headlight...what information you want "
What parts did you use? How did you mount it? HID or LED? Did you remove the outer lens to do the installation?
How long have you had the CS Racing exhaust?
Discussion Starter · #9 ·
Completely disassembled the headlight, painted everything black and used two 2.5" projectors. As far as mounting, that's a very long explanation 😂. They're LED's inside HID projectors. That alone took a pretty good amount of modification to the projectors. The high beam projector, I had to cut back pretty far and it isn't far enough. I will most likely make another one using my OEM headlight assembly. I bought a cheap $55 aftermarket assembly to do this one just in case I screwed it up
I've had the exhaust for probably 6 months or so. Had to wait 14 weeks to get it.
· Premium Member
silent mode on the most important part... man
does it work well, brighter at night, I just slapped an LED kit in the Busa and its no projector but its brighter and whiter than most.. 4 SMD Ceramic XHP50.2 HD per stick
1 - 14 of 14 Posts
