1 - 8 of 8 Posts
hi!!
I have heard that after the 2011 the suzuki gsxr have issues with the fuel pumps because they redesign it is that true ?
and i need to buy new fuel pump for my gsxr-1000 2014 as the title indicates, and i need a help to know the best brand out there ?
:crying::crying::crying:
sorry for my bad english i'm from the other side of the world.
Moderator
hi!!
<img src="http://www.gixxer.com/forums/images/Gixxer_2015/smilies/tango_face_crying.png" border="0" alt="" title="Crying" class="inlineimg" /><img src="http://www.gixxer.com/forums/images/Gixxer_2015/smilies/tango_face_crying.png" border="0" alt="" title="Crying" class="inlineimg" /><img src="http://www.gixxer.com/forums/images/Gixxer_2015/smilies/tango_face_crying.png" border="0" alt="" title="Crying" class="inlineimg" />
Why do you need to buy a new fuel pump?
You have an exceptional engine if it will operate at 10 RPM.
"I cleaned it and same problem"
How did you clean it? If you just cleaned the lower strainer, that normally doesn't do anything. The upper/main filter is where the real filtration is done and it can't be cleaned. Do the flow test as described in the service manual to see if it's the problem.
I haven't bothered to check in any detail but it seems to be a Mitsubishi T35 pump, which is an advanced design first used in 2007.
Discussion Starter #7
hi thank you for the reply
so normally it has reached 13.000 / 13.500 rpm .
for the cleaning i opened the fuel pump i changed the lower strainer, and i cleaner the regulator and the main pump motor, and it's the T35 Mitsubichi pump yeah.
1 - 8 of 8 Posts
