Hi, got a 2001 1k and the neutral light remains ON sometimes even in first gear and sometimes second gear, is there an adjustment i can do to correct it? Thanks.
If you have some knowledge on bikes you can do 2 things. Take it too a dealer. Or find the neutral switch and woring for the neutral light. It may be grounded on neg side causing light too stay on.
If u had a schematic finding the wire colors is not too hard. i sa ytake it too a dealer or someone with electrical knowledge and a schematic of your year/make.
Is it an intermittent problem? or does it stay on all the time.
If it stays on all the time then I would check the wiring to your GPS. If it is intermittent then I would check you GPS.
GPS is the Gear Postion Sensor.
