Hello everyone im posting for my husband he just traded for a 2006 gsxr and you can push start the bike and it runs BUT cant start it normally. We have tested the battery and the starter all good what else good be causing this all it does is click.
What displacement? Is the click coming from beneath and slightly behind the seat? That would be the starter solenoid. Find it and measure the voltage on the terminal associated with the big black cable to the starter. It should be zero until you press START, when it should jump to the battery voltage while cranking. Download a service manual for the bike. There's a diagram for the starter system on page 9-12. It should be easy to track down why it won't crank.
Possibilities include a failed solenoid, though they're fairly robust. How did you test the starter?
