1 - 2 of 2 Posts
Ok so I'm gonna try to explain this as good as I can. I have a 05 gsxr 600 and some guy cut the harness all up. The fuel pump primes the nuetral light is on. It will start with starting fluid but will not with the tank hooked up..once I figure out how to add pictures I will show the harness and will post a link to a video on you tube
"some guy cut the harness all up"
Without seeing the pic, I'd say the answer is a new harness. But you have to be careful there as most used harnesses are chopped up in varying degrees. It's commonly the turn signal connections, headlights, or the license plate light. But it can be much worse. I'd be thinking in terms of what does the new harness need and can your existing harness supply it.
It sounds like the computer can control the fuel pump and you have spark so I'd be thinking in terms of the injectors or maybe the tip-over sensor. But we need a lot more information.
1 - 2 of 2 Posts
