I have to replace the left side of my protek rear set.
I just need to replace the left peg and the shifter (think it's bent) on my '97 GSX-R 750.
Anyone know if I can get cheaper replacements than $51.20 direct from protekk?
· I <3 Item 9
you "think" it's bent. Better make sure before you buy new parts. You realize you can jsut heat up the shifter with a torch and bend it back with a set of pliers. Wrap a towel around it before you use the pliers and it won't leave a scratch. You can also straighten the footpeg to a small degree...
Ummm... that's not your bike is it? That's not a 97 750...
[ 12-20-2002, 10:28 PM: Message edited by: skidmark ]
Discussion Starter · #6 ·
<font size="2" face="Verdana, Arial">Actually my shifter is just bent, I'll try heating it and bending it carefully w/ a towel and some pliers.
However the peg was snapped and has to be replaced. I'll try calling Chris from http://www.ccpperformance.com/ and Dwayne from Cycle Concepts for the replacement peg since they're more likely to give a discount for gixxer.com member, which fucking rules
No that is not my bike, wish mine was that polished though
Thanks a lot for the great advice, I really appreciate it!
[ 12-21-2002, 07:40 PM: Message edited by: G-Spot ]
Discussion Starter · #7 ·
Originally posted by jp233:
you can get ProTek stuff cheap from http://www.ccpperformance.com/
call Chris (owner) and he will hook you up since you are a gixxer.com member
<font size="2" face="Verdana, Arial">Finally got around to calling him. Really nice guy! Said he could get it to me for around $25!
