Hey i was just wondering if i could get some info on some mods my 04' gsx-r 600 already had done to it when i baught it . I was wondereing if they increase the performance all that much and what the value of the mods might be? Any help would be awsome!
Mods:
Scat valve mods
valve spings
balanced camshaft
increased compression
balanced cam or crank?-if crank-it just makes it smoother & live longer,valve springs let it rev better,scat valve-none proven,increased comp. gives a little more power-but you must run really good fuel-poss race fuel at all times-or you can damage your engine
higher comp normally requires better fuel-you need to find out how hi it is-stock is already way up there & you're supposed to run premium to start with.There are alot of race fuels out there-everyone has diff make ups.If youre comp is a full point higher than stock-I would rec. race fuel at all times-your local race fuel vendor can rec. what blend to use-once you know your comp#
