Status
Not open for further replies.
what all is in the function drop down sides +/-? maybe null or off.. is there no documentation at all for this program or editor?
can you save this stock map or the map that works just how it is and set it aside?
try that save a stock base map set it aside.. looks like you have function offset at 20% + or -
then on teh left you have gears N thru 6 with RPM values in the table, what if you change them all to zero, OR an RPM the engine will never reach, say 15000?
not sure what prog you're using or how it works exactly, maybe change it to zero percent? or what's in the function drop down? is there a disable or something along those lines..
the Woolich makes it very simple.. what's that $100 or so and it does all sorts of other stuff too? long as you can save and load upa stock base map you can manipulate another map and load it up to change various parameters and see what happens?
maybe you actually do not have to disable it, but find the percentage that makes it work more to your liking? maybe add more fuel so the engine braking isn't as much? not sure what your goals are here but it's doable for sure, just need to figure out how your software is manipulating this feature, change, save, then load?
I fixed it by copy and paste al the values fron the N gear over to 1 till 6 and clutch now its off
That’s Mister Moderator To You ....
Closing thread.
New guy post questions ONCE, in the correct forum and wait for replies. This is the third thread you've posted about this.
Status
