06 gsxr good stator and rectifier and battery ive tested all 3 good reading Number are coming back and the syatem still want charge I’m lost can anyone help
welp if you disconnect the battery and it wont take a charge its bad or your charger is bad, do this and if it takes a charge disconnected but not connected then try a parasitic test and charge system.. check and clean grounds specially main
K1 2001 GSX600R (little bitch) 1978GS1000 (Ghost))
Have you load tested the battery or just voltage test and what are the figures of volt tests ex " idle 500rpm lights on /off ?
