I need to replace the clutch lever assembly on my 750. When it fell over I guess the lever hit practically perpendicular to the ground and instead of the lever snapping the bracket itself bent in because now the lever's farther forward than normal. I just got the part in but have some questions.
How exactly do I remove the left handgrip and switch assembly to slide off the old bracket and slide on the new one?
I'm assuming I'll have to remove the left bar end in the process. If that's correct is it possible to remove it without mangling it so I can put it back on? On my last bike I had to impact wrench the bar end screws off so I was thinking maybe I should just replace the bar ends too while I'm at it (maybe with the Motovation ones - any other good ones to look at?)
Thanks for any advice.
