Yea hi I’m new on this page however I will get right down to it, I have a 2012 Gsxr 1000 recently recovered from thief I’ll post a before and after picture. However the bikes ignition was hammered out and you can turn it on and off with a flathead screw driver, the whole throttle module was gone so I replace that hooked to the two wires up easy fix then turning on the bike the fuel pump kicks on and it won’t crank any ideas? I just prefer the whole ignition unit.
568675
568676
568677
568678
I believe there are several posts here about the C42 code. Might try a search on here.
I think C42 is an ignition switch code.
There is a resister in the switch that can burn out and trigger the anti-theft system to kick in.
Given the state of your ignition switch, I would guess that the switch is indeed the problem!
GSXR Fuel Injection (FI) Code List:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (1000 ONLY)
