1 - 9 of 9 Posts
My bike started to take longer than usual to start when its cold so i thought to change the spark plugs after changing them the bikr rattles and rpm breaks a little bit between rpm's 2 nd 4 only then its okay as if its running on 3 spark plugs only but i checked and all 4 are operating i really dunno what to do
Well, it should start instantly, so you might want to check the fuel pump with the fuel flow test. And check for FI codes. Also, you need to check that everything is plugged in and that your spark plugs are tight.
Did you reconnect all the hoses, in particular the IAP sensor? Might your ISC valve need cleaning? Is the throttle position sensor properly adjusted?
Check your fuses there could be a dirty connection and check all wires and leads below tantalising something isn't connecting right I think
Sent from my SM-G935F using Tapatalk
Definitely double check yourself. If this problem didn't start till after you played with it then something is off
Sent from my SM-G920V using Tapatalk
1 - 9 of 9 Posts
About this Discussion
6 Participants
GunMetal81
Full Forum Listing
