Just got my bike back going after looping it a couple months ago. Now it seems to be building up fuel in the carbs. I rode it for a while tonight testing it and when i run it above 4500 rpms for a few minutes its alright. But below 4500 for a few and it sounds like a v-twin in the lower rpms. It goes away after i get into the throttle a little bit. Im thinking maybe a float is sticking or out of adjustment. Am i close or do you guys have any other ideas. I checked the fuel lines and vacuum everything seems ok. Thanks for the help.
ona different note, my email has been down mostly today....ill quote tomorrow once i finish catch-up....
expect MUCH BETTER satisfaction with the decals....
cuz its at low rpm's, maybe a bit of damp has got into the plug leads/plug wells.
only saying that cuz mine did the same after a good wash, and wd40'd the plugs etc and that cured it.
Checked the plugs and they are ok. It seems to happen only after temp gets above 170 also. Anyone else have any ideas.
Yeh, the carbs are worth a look,especially if it was sitting around while getting fixed.You might wanna throw a set of plugs in there too,if it's been flooding it can kill them(though you usually get a miss at revs)and they are cheep
Discussion Starter · #7 ·
anyone else got any ideas I pulled the fuel valve and all, inside of the tank is clean, checked for visible vacuum leaks cant see any. I guess ill have to tear into the carbs. Kinda dreading that though.
