1 - 10 of 10 Posts
Bearded Viking Admin...
At least the '96-'99 750 and the '97-'00 600 locks will fit, possibly the later models too. Don't forget a lock for the trunk. Check out eBay for locks, they are sometimes sold as a set with all keys when street bikes are converted to race bikes - or are salvaged...
it's the trunk lock that may not fit. I'd get the right set.
you could also have a locksmith re pin your current locks if you are worried about someone finding your key and stealing your bike. It would be cheaper than buying new locks.
good luck replacing that gas lock with out a key to pop it up first. you will have to get a key maid for it.
look in your manual it should have the key number in it. then the dealer can make you a new key. at least thats how it is for my 96 gixxer. key number was hand written into the manual.
I would need to buy a Suzuki blank key first right? So I should be able to remove the trunk lock and get them to copy it from that? What about calling Suzuki and seeing if they can look it up by the VIN number?
I good locksmith will probably already have it. I just had a spare made at a local locksmith and they carried the blanks.
gixxerman
1 - 10 of 10 Posts
