1 - 20 of 21 Posts
2000 gxsr 600
I need to replace my clutch, and by what by buddy says...... a clutch fork (cause it's bent)
I have never replaced a clutch on a bike before (just cars) so I was wondering if anybody has a "HOW-To" thread, or link that explains on how to change it.
I just orderd a manual from suzuki (cause apparently, my year they don't make a generic manual. so i got to go OEM) cost me $75 and wont be hear for about 2-3 weeks they say. and since the weather is nice still. I want to try and get my bike back up before it strts rainin.
TIA.
Mike
Savage600 said:
2000 gxsr 600
TIA.
Mike
What gives you, or your buddy, the idea that your bike's "clutch fork" is bent?
Changing a clutch isn't too bad...pop the bolts out, remove the basket, repack the basket, including new springs, re-install basket, check cable movement, close back up.
He Who Touches Himself
Tell your buddy he has no idea what the hell he is talking about. No such thing as s clutch fork.
Like turbo said, it's pretty straightforward.
PM me and i'll give you exactly what you need!
Good luck!
Discussion Starter · #5 · (Edited)
It was actually the clutch rods. it's number 14, 15, and 23 that needs to be replaced. along with a clutch. I was going to try and get a clutch 2day. but not sure which one to get.
I'm not going to be racing, or stunting. just riding hard when we all go out.
so which clutch would u recommend??
I went onto www.indysuperbikes.com and was looking at the barnett high perf. clutch, or the DP street clutch.
stock one, i got one for $85 off of wera with 100miles on it.
and when u replace a clutch, replace the whole thing.
Discussion Starter · #7 ·
I got the whole clutch kit. (friction plates, springs etc) and the 2 rods (#14,15)with seal (#23). (because the rods were slightly bent) is there anything in the diagram I should get?? that doesn't come with the clutch kit????
You will have to split the engine case to replace #23!!!!
Where did you get kit from? How much?
Discussion Starter · #9 ·
R u serious? I thought that seal was the seal that goes on the rod?
and I am getting the EBC clutch kit from santa clara cycle. for about $100 +tax
which I think is a good deal. cause everyone else was charging like $120-130
When you remove your sprocket cover, the first clutch push rod is what you see sticking out. The seal that it goes into is #23.
Nope, that's it.
Good luck!
OK - WAIT... Something's not right here.
How in God's green earth did you damage the clutch pushrods? And not just one pushrod... both???? I've yet to see that happen. And I can't imagine how it possibly could happen. The outer pushrod - maybe if you threw a chain and it ripped it out. But the throwout rod? No way.
Honestly bro... I would get a second opinion. I don't think your friend is qualified to be diagnosing problems with your bike. Just my .02.
he's got a point. When you get everything apart, take a GOOD look at everything.
Discussion Starter · #16 ·
he's not sure that both are bent. he knows that one is (I believe the inner one) I just want to get both just incase. and if the outer one isn't damaged. I might just replace it anyway. cause it's only like $15
and Im gonna take some pics with my phone 2day. and post them up 2nite.
cause everything will be here tuesday. and I have tuesday off. So I'm gonna swap it all out then.
I am going through the same thing on my 2002 GSXR 1000. I tried to pry it out, but it didn't work. I just pulled the motor out and I'm gonna have to split the cases. It's not that hard, just alittle work.
Are you talking about the clutch pushrod seal?
1 - 20 of 21 Posts
