I would be extremely careful when trying 1st gear wheelies. I have an 06 600 and it comes up very easily if you know what you are doing, and it can loop you with no problem. The way you are trying to to it, no you probably wont be able to pull the front up. Take the redline up to around 10k and then let off till 7500 or 8k and then crack it. The front should pop up. Be careful and im warning you, when it comes up in first it comes up fast. Being that its in 1st gear the throttle is extremely sensitive. Hope that helps.
