1 - 13 of 13 Posts
Dudes (and Dudettes),
I'm going to install a secondary starting system on my GSXR1000. I just don't feel that the electric start is reliable enough. Should I go with a kickstart or a rope pull start? Have any of you made this modification yet?
i think migs maybe able to develope a 2 hp pull starter, so now all you have to do is remove the tank, put fuel in alot of ziplock bags to replace the tank and mount a lawnmower engine there for cranking power!!
Yeah, but how do I start the lawnmower engine? That's a good idea, but if the lawnmower engine is equipped with a pull rope, then I have to have an auxilliary electric start installed for it. I'm thinking that I need to install BOTH a kick starter and something alont the lines of what you mentioned. Or, a rope starter and a kick starter. I think also maybe if someone could come up with something like a big suction cup that I could throw at passing cars and is attached to the rope start....
Fit a centre stand, put the bike in gear with the ignition on, wrap your string around the rear sprocket, and pull hard (once the bike fires up, it might be a good idae to let go of the string)
fit a trailler and in it carry a paddock stand and a remote starter (ie ducati WSB starter) that drives the back wheel to 80 mph and then drop the clutch and itl start
Well, I'm currently working on putting a compreessed-air starter on my gixxer in addition to the pull-cord, kickstarter, and original electric starter. This will complement nicely my UPS back-up system for the ignition computer and deisel generator back-up electrical system.
Discussion Starter · #8 ·
Sounds good! Keep me posted on the R&D progress....
NO NO guys, you are going about it all wrong...
You need to do like I did and install the kick starter in front of the left peg. Not only will this give you plenty of clearence in case you need to change your glow plugs, but you can also use it as a quick action reverse if your stock one goes out. I know when my reverse went out on my '97 750, I used my kickstarter to fix it. It was a snap, all you do is attatch it to your hydroxy oil pump shaft (Just under your cupholder)
and simply crank the shaft the opposite direction of normal rotation. I hope this was of some help for the new guys, if you have anymore questions about mods to your bike, just PM me and I will be more than happy to assist.
Well, so far it's a prototype-only... I'm having trouble finding tires that are VR-rated and also have a high enough load capacity... the prototype only weighs in at 3,200 lbs though... definitely one of the lightest emergency deisel generators ever mounted on a motorcycle!
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr> It was a snap, all you do is attatch it to your hydroxy oil pump shaft (Just under your cupholder)
<hr></blockquote>
now i know that cupholder wasnt a factory option, or else i got screwed.
HOw bout an electric drill with the appropriate sized socket install on the side case, directly turning the crank shaft. Or you could put the kick start crank on the crank shaft and hope it falls off when the bike does fire up. i don't think it would be too good to have a kick starter spinning at 1500 rpm's let alone red line
Cock Thumb, or Thumb Cock? You decide.
<font size="2" face="Verdana, Arial">NO no no.. 3 words.. ONE WAY BEARING.. problem solved case closed...
1 - 13 of 13 Posts
