1 - 10 of 10 Posts
Well not mine in 2 ways:
1. His idea, that was another's idea http://www.gixxer.com/forums/16-water-cooled-gixxers/573609-stick-coil-conversion.html
2. Family just will not give me any garage time and I need lots of time when it comes to electrics! So off to a friends place (G6 Motosports) for some custom wiring.
Job: Shorten and tidy up wiring harness, eliminate unnecessary wiring, ....
.... Maybe wire in OEM Race only CDI or Vance & Hines CDI, modify Yosh racing harness for street use or use as a copy to custom build for track days. It all depends on $$$$
So, my SCARY HALLOWEEN is giving my bike over for someone else to fix!
We got problems! Bike will not run! Stck coils have spark. Bike Spits, sputters,...Put the stock coils back on and runs fine. Where to look?
Looks like it is figured out! Update to come...after Turkey Day!
If I pulled off a post like this, I'd get crapped on big time, oh wait, 'Big League'
I'm glad you can pull it off
Discussion Starter #7
First run after coil conversion. Also, had G6 adjust the valves. The exhaust side was good, but intake was tight.
Discussion Starter #10
Finally had some garage time and warmer weather. Sorry, you can't hear what I'm saying.
I had to re-route some wires, hoses, and run some non-ethanol gas through the carbs and run them dry, remove the battery and put the bodywork back on.
1 - 10 of 10 Posts
