1 - 12 of 12 Posts
Well, our gixxer.com SRAD expert pulled my motor last weekend to see why it was still making a clacking noise.
We had tried replacing the cam chain and guide, and that didn't work, so we replaced the cams, chain, and crankshaft posistion sensor from a known good motor, and it still made the clacking noise.
So he dropped my motor, and then pulled the head. It turns out the #4 Rod bearing is messed up. Luckily the piston wasn't hitting the head though. Also, I guess I was blowing a lot of oil past the rings.
SO, I need the motor rebuilt. New crank and rod bearings, new rings, new valve guide seals.
Poor bike
Hey dont worry... She will be better then new when I get done with her...
<font size="2" face="Verdana, Arial">OK, OK, I'm not really worried about my bike, I know you'll do an excellent job fixing her up.
Maybe I should have titled the post
My Poor Wallet
The question is how much power do you want??
I can clean it up and make it run good no problem.. You want more power and we can talk about ways to do that too...
Discussion Starter · #6 ·
<font size="2" face="Verdana, Arial">What exactly do you have in mind? Leaving the center part of the head gasket out?
Yes if there is room.. I have to find out if there is enough room to remove it and not have the piston hit the head.
dang ratman that sucks.... how about just a new motor? I mean with all the labor it might be easier to buy a motor and just drop her in... then you could part out your motor as is and make some $$ back (like sell your motor to me
since I am goign to get a SRAD 600 frame and put a 98-99 750 motor in it
man...thats the shits..how many miles??oil changes on a regular schedule?? suzukis usually have a bullit proff bottom end..
well he is going to get a killer deal on labor... But I wouldnt trust a used motor without tearing into it anyhow... Just MHO...
Also, When the motor goes back in it will be like new again...
Discussion Starter · #11 ·
Yeah, if I get a used motor, I have no idea how it has been treated and how long it will last.
Nice try though, jp233!
The bike had about 17,000 miles. I've heard that the #4 bearing is usually the first to go because of oil starvation due to wheelies, which is odd, because my wheelies are never very high or long, and I always keep my oil filled to the high mark.
John, could it be that a piece of that gasketmaker shit that the shop used when they changed my clutch got into the motor and blocked and oil port, and that's why it happened?
[ 05-07-2002, 05:59 PM: Message edited by: ratman69 ]
Yes it could be from that... But to prove it might be hard. I will see what I find and I will keep an eye out for anything funny like that...
It sucks that people would use something like that....
This is a GOOD reason NOT to use gasket maker in your motor.
1 - 12 of 12 Posts
