I finally got my 01 out of storage and running... sort of. it has a deffinate miss and black smoke coming from the pipe. I pulled the tank and cleaned it out, pulled the injectors and the little filters inside look ok, nice and white, but there was some gummy stuff on the out side of the injectors near the actual tips, flushed the fuel rail and fired her back up... still the miss.
Any ideas?
We don't know if there is anyway to open the injectors to check/clean the tips?
Sounds like you need to isolate the problem a little bit.
Start the bike, then pull each plug lead off - one at a time. When you hear a lead that DOESN't change the note of the engine - that's the one that's giving you the problems. Then you can concentrate on that cyclinder's - spark plug, injector, lead, etc etc.
Si.
my friend bought a K1 that had a similar problem. I did a basic tune-up (the spark plugs were really bad and i think that was the problem) on it and it ran great after that.
