has anyone installed a msd 4350 launch master on a 04 gixxer 1000. i installed mine as direction said so and it never shuts off. what ever rpms i set it at even works and if i try to ride the bike it wont go beyond that setting. so i disconnected it. every thing is direct connect but two wires. the black ground wire that ground that goes to the battery (-) side and the blue wire that goes to clutch ground. even when i let off the clutch if the launch master kick in again at what ever setting i have it at. does anyone have a clue why that is?
You have the act. wire wrong. It should only be on when the clutch is pulled in. You don't want the red light always on only when you pull the clutch.
the red light is always on and its always active if the clutch is pulled in or out
U tapped into the wrong wire on the clutch, go to the other wire and it should work perfect!
The clutch switch is just like a toggle switch.
Are u using a ground or positive act.
About this Discussion
4 Participants
mrempire
Full Forum Listing
