Yes, I have the bar ends. I can see the instrument cluster shake a bit when reving in neutral. My clutch is shot and I haven't been able to ride my bike but I still crank it up. After the bike has warmed up I usually rev it a couple of times and while doing this I feel the vibration and see the cluster shake. Hope that helps...
Here is your "R"
Sounds like a blown clutch basket, take off the clutch cover and replace it. They look like bowls and if a part of it breaks off it throws off the balance in the motor and clutch wont work right. Becareful I wouldnt start it, I am sure you have broken parts floating in the oil.
