1 - 1 of 1 Posts
It’s happened to every rider. You get geared up, walk out to the garage, and flip on the ignition of your motorcycle, but when you thumb the starter button, you get the dreaded clickety-click-click. Now, your ride is in jeopardy. Well, our friends at NOCO have a solution for one lucky MO reader. NOCO has generously offered to give away one Boost Sport 500A UltraSafe Lithium Jump Starter and a GENIUS1 1-Amp Smart Battery Charger. With these, you can have both sides of the dead battery issue handled.
Automotive lighting Communication Device Font Gadget Tool
The GENIUS1 1-Amp Smart Battery Charger is one of NOCO’s most powerful, highest-performing, energy-efficient, and compact chargers available. The GENIUS1 is a 6-volt and 12-volt battery charger, battery maintainer, and battery desulfator rated at 1-amp for lead-acid automotive, marine, and deep-cycle batteries, including flooded, gel, AGM, and maintenance-free, plus lithium-ion batteries. Yes, you read that right, lithium-ion batteries, too. An integrated thermal sensor detects the ambient temperature and alters the charge to eliminate over-charging in hot climates and under-charging in cold climates. Charges dead batteries as low as 1-volt or even down to zero volts with the the all-new Force Mode.
The GENIUS1 is easy to use. Plug-in, connect to the battery, select a charge mode, and start charging your battery. A fully-automatic, worry-free battery charger for year-round use. It even detects sulfation and acid stratification and restores lost performance for stronger engine starts and extended battery life. The GENIUS1 can charge and maintain the batteries in all types of vehicles, not just motorcycles. The GENIUS1 carries a $40 MSRP.
Input device Automotive lighting Electronic instrument Musical instrument accessory Gadget
The NOCO GB20 Boost Sport 500A UltraSafe Lithium Jump Starter will get you out of almost any dead battery situation you can find yourself in, and we can’t tell you how many times we’ve had to pull out a jump starter at a track day because someone left their key on after an exciting session. The GB20 is a portable lithium-ion battery jump starter pack that delivers 500-amps for jump starting a dead battery in seconds. NOCO claims the GB20 can deliver rated at 500 amps for up to 20 jump starts on a single charge. It features a patented safety technology that provides spark-proof connections and reverse polarity protection, making safe and easy for anyone to use. It’s a powerful battery booster that doubles as a portable power source for recharging USB devices, like a smartphone, tablet and more. Designed for a car, boat, motorcycle, RV and more with gas engines up to 4 liters. It also features a bright 100 lumen LED flashlight with 7 light modes including SOS and emergency strobe for roadside repairs or signaling for help. Finally, the Precision Boost Battery Clamps are designed to easily connect to any 12V lead-acid battery from power sports to trucks. The GB20 Boost Sport 500A UltraSafe Lithium Jump Starter has a $100 MSRP.
Now, it seems kind of silly to have to say this, but if you want to win, we have to notify you that you’ve won. So, you’ll need to enter a functional email address and make sure that the Motorcycle.com domain is whitelisted with your spam blocker. You have no idea how many entrants have missed out on their prizes because they never responded to the notification email and forced us to move further down the list of entrants. Do the right thing.
Enter giveaway here
1 - 1 of 1 Posts
