1 - 2 of 2 Posts
My motor squeeks when idling. I'm not much worried about it because it has always done it. Just like to know what causes it?
Another thing is that 3rd gear howls at lowish revs. I read somewhere that the hardening has come off the gears. Is that right? The box shifts perfectly.
Thanks in advance for your replies.
pull the valve cover and check to see if a rocker arm has been worn also check the cams like i mentioned before...if at any point in time the cams or rockers gor dry it could have worn the hard facinfg off of the rockers and evry time the cam lobe comes around onto that rocker arm it squeaks...check it out and let us know what you find...
1 - 2 of 2 Posts
