Does the '89 750 head fit on an '87 1100 (1052)? Does it give any advantage?
Thanks all. Troy 341
Yes they will bolt up, the main advantage is more compression. Other than that there is no real advantage. ports and valves are about the same.
YAAFM Mod
Actually the 88-89 750 head has the larger valves of the 1127 engine unlike the 85-87 or 90-92 750's
also the ports flow better.
Bones
According to A.P.E. and Ferrea valves:
86/92 750:27mm in/24mm ex.
86/92 1100:28.5mm in./25mm ex.
