1 - 12 of 12 Posts
I ride my bike for like 45 min and it was perfect but i came to a stop and when i try to take off bike start hesitant bad (like misfire) to the point i stall 3x. The only way i could take of was having rpm over 4k and it jump bad like misfire until clear after 4k rpm was stable. So long story short below 4k rpm sound like misfire and hesitate hard, one i pass 4k rpm is like the bike is new.
I ready replace the following parts:
Stator
Rectifier
Battery
Spark plugs (2 different sets)
Ignition coil
Stva
ecu
Fuel pump
Fuel filter
Injectors
Oil
Replace vacuum lines on buddy throttle
Any idea or suggestion.
· Dreaming of buttsecks for years...
Might be time for a compression test. Did you just get this bike? You might want to just check the cam timing as well. If someone else got in there and tried to adjust and made a mistake, it can cause weird issues.
The other thing to try is unplugging sensors one at a time to let the ECM insert the static values. It could just be the ECM doing the right thing with bad data.
I hade the bike for like 6 month. But i hade ride it before multiple time and no issues prior. But ill look on the unplugging the sensor to test the ecm i already put a new one and didnt make a difference. I thought is call ecu but is the ecm what i put new as well hunting for the issue
Discussion Starter · #6 ·
Update.
I just did a compression test and for some reason it show 60 psi on all 4 cylinder. I know it required 171 to 228 but why ones it pass 4k rpm have lot of power? Any idea or advice
I would have to put hands on it and perform some diagnostics. Also at low RPM, the engine has a higher vacuum. Could indicate a problem with the IAP hoses/sensor. You have to do the diagnostics.
So any idea why at take off it bug out (misfire) almost imposible to take off and now even more questions why it have 60 psi on all 4 cylinder but ones it pass 4k rpm it have lot of power like new?
The 60psi is most likely you have the wrong type of compression tester. Not suitable for bikes.
The video sounds like a misfire, could be coils or injectors related. I'm leaning towards coils,
because you said it misfires under load and when hot. You said that you replaced all the coils. Were they new items?
Edit: ( I see you started another thread, so I will go there).
1 - 12 of 12 Posts
