1 - 12 of 12 Posts
Hey Guys,
What type of cleaner do you guys use to clean and will not scratch up your mirror type face shields? The over time, the Honda plastic cleaner leaves a cloudy film on the mirror type face shields. Thanks
I tried everything and the only thing I found that worked with no downside at all is a spray from a company called California Optical. The stuff works great. seems like the more you used it the more effective it is.
No affiliation with company etc... the only place I found it was at my optician... he gave me a sample and said to try it.. works on all coatings etc for glasses.
If you have a Shoei shield DO NOT use Plexus or Windex. Only use a mild soap and water with a soft, clean cloth. Don't use those two products on the helmet either, they will slowly turn the clear coat yellow due to the chemicals. Use Honda Pro cleaner on the helmet and soap and water on the shields (applies to all of them). If you want to really buff your helmet up find a product called Novus Plastic Polish, it comes in a set of three compounds which can be used to remove fine scratches and polish the helmet and most shields, only use the fine scratch remover on the regular shields, don't use any on the iridium shields.
1 - 12 of 12 Posts
