1 - 10 of 10 Posts
I dont have a tire machine and dont like driving 2 hour round trip plus paying money to do a tire swap.
I bought a nice gravity balance with cones etc.
I have tire irons and rim protectors, but breaking the bead was a challenge.
I got an old piece of oil field pipe spool fromthe junk pile and spent 30 dollars at Tractor Supply.
Some metal strips for support on the wood, bolts and nuts & some straight pipe.
I had an old bike lift stop I cut and hammered out for the tire wedge. Pulled out the chop saw and welder.
It's super primitive, but it works great.
I will add, it was harder than I thought to get everything right s far as geometry.
Nice work,
I like the DIY stuff
What part of TX you in?
Nice work,
I think you posted here before seeing my location post in the garage thread.
But yea, if something is doable I need, I'l make it instead of buying it, plus this one is way stronger than some of the cheapies I've seen.:smile:
I tried tire irons with rim protectors and bent a rim. Had to have it straightened. I said to myself, f%^k it and went and bought a machine.
Love DIY custom stuff though. Have a whole lot of DIY bearing tools.
Thats a nice setup you have!
Older,long time street racer/close friend did all his own work and showed me a trick on how to use an old-school bumper jack from a car to break a bead on any bike,car tire. Have used this way exclusively since the early 90s when
I was a young buck w no money and even less patience to have a shop spend all day changing tires. I'll post a pic of how it works,even use it on my BST's:biggrin
I have lots of 'old' stuff, and still don't know where I can find one of those type jacks.
I will though, when you post how that works on the MC tires.
Discussion Starter #7
You remove tire valve core, put jack under receiver hitch etc. and the botton goes on the edge of the tire. Ive seen it done before though.
I used to have a KZ1000 with a wedge side stand, I used it to break the bead by grabbing the handlebar and pulling on the seat sideways.
When I was a kid, we changed our own tires all the time, burned them off faster than I could find them :lol
Ok,so this is my top-secret,ghetto-fabulous,hillbilly home-made bead breaker. Only a few close friends have seen this and I like to keep it that way,so don't go tellin' everyone about it :shifty
I welded a short piece of 1" pipe to a lally-column in my garage,about 24" off the floor. I put a small notch on the bottom of the pipe so the lip of the jack would sit securely and have a place to bite and not slip off.
Remember,these bumper jacks from the 1960's were super dangerous and had a tendency to fucking kill their poor owners trying to change a flat tire:biggrin
I put the curved side of the base plate along side the lip of the wheel,making sure the jack is level with the lally-column. I also put a 2'x2' 5/8" thick piece of plywood on the floor and lay the wheel on top of that,I was to lazy so its not pictured.
Rectum Rupticus
That's bad ass . :cheers
Thanks Coop. With all the rear tire changes I do,a used tire machine would be a wise investment. But as crude and simple as my bumper jack method is,it's effective and I can break the bead,spoon the old tire off,spoon the new one on and be done in 10mins tops.
1 - 10 of 10 Posts
