As with any mechanism with moving parts, it it gets sticky it should be cleaned before being lubed. With a lock tumbler you can't reall disassemble it but you can give it a try.
There are two bolts holding the ignition tumbler to the top clamp. remove them and free the tumbler. It should disconnect from the harness.
The seat latch/helmet locks also are held by a couple of bolts.
The gas cap lock is a no brainer.
It they were MY locks I would do what I do with the locks I have on our sheds and out door exposed locks(aka Master Lock padlocks)...
Get a few cans of a spray solvent (like Gunk engine cleaner or a similar oil-based cleaner) that can have a spray tube (like a thin straw)attached to the nozzle.
Insert the spray tube as deep into the lock as possible and spray solvent into the core. I'd do this several times.
In-between sprayings work the key in and out, turning the mechanism back and forth. This should free the crap and let it get flushed out by the spray.
When it starts to feel like it should, or like you want it, spray a good oil-based lubricant. Yes, you'd rather have graphite but there aren't any that will displace the solvent. Oil it is. Repeat the spraying until you're confident that as much of the solvent is displaced/diluted.
The lock should be ready for use.
