Hey guys a have a k7 1000 gsxr and I’m wondering if I could lower the rev limit ( with clutch ) from 8000 to 6000 or around that, anyone has done it before what’s the side effects
Wut
There are several that can do this. It was available as early as 03. I am going to send my flash back to get it added as I did not think about it.
For the others, it is poor mans launch control. When the clutch is in the flash can add a lower rev limit (say 6000 RPM) to help you upon start. Feather out the clutch and go!!
I'd rather have a 2-step.
Hand-Eye Coordinator
ECU flash will do it. That's easiest in MOST cases.
Would you happen to have a power commander already hooked up? If you do, you can buy a Dynojet ignition module and install it. There is a port on it that you can run the clutch switch to and will allow you to adjust the rev limit with your PC, basically having a "clutch in" map and a "clutch out" map. That's not all it does, but it'll do what you are looking for.
