1 - 18 of 18 Posts
I just ordered the lowering links off ebay. I want to slam the bike like my old 02 gsxr 1000. If i put it on the lowest setting on the links, i think its 3". How far should it come down in the front? I usaully just slide the forks down 1". But is there a real measurement?
Re: Lowering my 05 gsxr 1000. How far do i lower the front?
well, what i plan on doing, once i lower the rear, i will measure the amount dropped, then i will lower the front measuring a static point, like the fairing stay, to lower it the exact same amount
Cool..
I'm going to try to drop it level. It might be better to lower it more in the front to keep it down when 1/4 racing it.
Ill have to try it higher and lower in the front.
Thanks.
I don't think that the 03-04's can be lowered on the triple tree like the 01-02's...I heard that the upper forks were tapered so you can't lower it but about 1/4 to 1/2 an inch...
I found out today that you can have some spacers put inside the forks and lower it without touching the forks in the triples....That would be the way I would do it if I were thinking about it...You retain the stock look on the forks and its slammed...
Discussion Starter · #7 ·
My friend just lowered his 05 gsxr 1000 and slid the forks down alot.. Like 1 1/2".
you can try it, but I know i've read about this topic on this site before on the 03-04's, the upper fork is tapered and you can't lower the forks much.....
that is true, you can only lower the forks like 5-6mm in the triples due to the taper of the fork tubes.
Discussion Starter · #10 ·
Is that just on the 04 1000? Becuase my friend lowered his 05 600 alot more than that.
You can lower it alot and not have to worry about the triple clamps. It is the clip ons you have to worry about. I lowered mine the first time and did not pay attention. My clip ons only had about 3/16 inch on the bigger part and the rest on the smaller diameter. So only 3/16" of clip on was gripping the fork tube. I rode around for awhile and then on one of my launches the clip on came off causing my bike to tuck the front end and go into the other lane. I almost crashed.
The 03-04 does not have the bolt holding the clip on to the triple. I put a set of vortex clip ons on my bike to get ride of the problem.
your comparing two different bikes....the 1000, 750 and 600 have all undergone alot of changes in the last couple of years....
SOrry I know this is kind of off topice but I just bought DOG Bones to lower my '01 GSXR1000. Can you tell me if they should be longer or shorter then the stock links?
I was thinking they would be shorter but I am not sure.
Thanks.
how many settings doe it have on them? 3 hole or 2?
My post earliear was refering to 03-04 1000's as that is what he asked about.
The longer the dog bone the more it will lower bike.
It is a 3 hole dog bone. It seems that Shortening the bone would lower the bike but I see that it is really the other way around.
yip....Wierd how that works till you see how its installed..
i know im reviving this thread from the dead, but im about to lower my k4 1k, and im wondering about the clip ons i can change to make the top clamp down correctly. my question is whcih size do i need? the vortex clip ons come in a lot of different diameters and im unsure of which ones i need? or, what other options are there to properly lower the front on the tapered forks?
1 - 18 of 18 Posts
