I want to rasie my bike up to stock but cant figure out how the front is suppose to work. Any good advise would be good.
Bearded Viking Admin...
Here's a stripped down view:
As you can see, the fork legs are clamped into what's called triple trees or yokes.
To move the forks down you obviously need to unload the front. Then you loosen the pinch bolts on both triples and the clip-on handle bars and the legs can be moved. Tighten back up in this order: lower, upper, bars. Don't overtighten.
Mr Creepy McCreep
i wouldn't suggest that you could bend or kink your headers or possible break the studs off into your block, it could happen didn't say it would
About this Discussion
5 Participants
wannagsxr30
Full Forum Listing
