Hello, im trying to fix 2nd gear issues on a 1127 from 1989.
I have the lower case completely loose on the clutch side but something is holding it near the starter clutch assembly. I can lift it maybe 2-3 cm before it stops. I have not removed the starter clutch because its stuck to the crank and i dont have the tool for it, is that the reason i cant get the case off? Im sure its not any bolts holding it because i can wiggle the case around alot.
Can someone please tell me what i need to do to get the cases separeted? Im in a hurry to get this bike together..
MY bet you haven't taken off the oil return tube since you can lift it a bit but not fully.
BTW theres a bolt hole on the back and a slot on the front where you can put 1/4 5mm bolt and nut and bolt to separate the cases
I cant belive it!! Today the case just lifted of, i didnt do anything with it and yesterday i tried and tried and tried for atleast 30minutes until i gave up.
