1 - 12 of 12 Posts
Not on me, on the bike!!
Pulled the stator/magneto along with the flywheel and bolts. I weighed those parts after at 5 pounds total so now my bike is at 356lbs wet.
Hmmm . . . where else can I shave off weight (on the bike!)
Bike fired up nicely (actually I forget it was in gear and it still started fine) and damn it revs fast, REAL fast.
Now i just have to lean out the FI and take advantage of some untappped power.
Bearded Admin call him Grizzly
may I ask why you would take out the charging system out of the bike, dont forget to recharge the battery inbetween races bro
less weight on the crank to spin over, less rotating mass, less weight overall.
I already have put on quick disconnects for the battery to allow for charging in between sessions.
I know the mechanical side to it but wanted to know why you did it since if by chance you forget to plug it in it could cost you a race
only needs a 30 minute charge to get 30 minutes out of it. Worst case scenario it gets plugged in with the warmers.
After the bike is fired up, do you actually need the battery in there at all?
I saw a guy at the track, that every time he started his bike he would hook a battery up to some wires at the tail section, start the bike, then disconnect the battery and be on his way. I would think the weight of the battery would be a nice few pounds to lose. Of course, don't stall the thing on the line!!
You saw a guy who ditched his battery and kept his charging system
Gotcha. Can't have it both ways, eh
I give it until after october before you have the charging system replaced...
But if it works for you, then see what happens..
R
Discussion Starter #10
Why would they take the battery off and leave the charging system? Seems rather silly. Much more benefit to keeping the battery and killing the charger.
Anyway, I have no doubts this will work fine. Many many top riders I know run this way using only Battery Tenders. I'll be pumping a lot more juice with a full size charger.
Well, if you got a full size charger and they only have a tender, I'm betting you'll be faster than those top riders now
The bike will not run without the battery. Yamaha used used to hook a battery up to Gobert's bike to start it, so it wouldn't kill the little on board battery they used to run the fuel injection and ignition systems. A charging system alone will not run a bike(not a modern four stroke fuel injected sport bike)
Some bikes do run just off the juice from the stator, but mostly off road stuff.
1 - 12 of 12 Posts
About this Discussion
6 Participants
Ryno
Full Forum Listing
