1 - 9 of 9 Posts
can anyone tell me what the problem is? my headlights/tails, gauge cluster lights seems to flicker when i ride and dim when i rev..im thinking there could be a short somewhere...help.pls.
My headlights/Guages Dim and Brighten as I rev Its normal!
battery isnt up to par !
That's what tipped me off to the rectifier crapping out. You better check it out before there's a big problem. Dealer will charge you an hour to chaeck and advise.($65-75)
I had the same problem awhile ago... I would rev my bike up and all gauges would shut off and headlight would dim down bad. I charged my battery for a few hours and that took care of the problem. Haven't had the problem again. It could also be a bad rectifier(sp?) Which is located on the left side of your cdi box mounted to the frame. It's a greyish color with cooling fins. Good luck! If it's your rectifier check out ebay, they sell them there cheap all the time.
[ 06-02-2002, 05:18 PM: Message edited by: gsxrfever ]
No... I believe the rectifier(sometimes called a regulator) regulates the voltage. Not quite sure if that is the complete function or not
check your ground connection at the battery ...that was my problem..it vibrated loose and the lites started to flicker..hope its a simple fix...
1 - 9 of 9 Posts
